Wood Sheathing & Intersection Properties
I have altered a few of the Default AC17 Intersection Properties for some of the Building Materials (BM) and have also added a few new materials like Wood Joist, Wood Rim. I am curious what others are doing?
attached is a section with (2) floor and wall intersections. The wall contains a BM called "Wood Sheathing" that I believe is a default BM (I also created a Wood OSB). The upper wall and floor intersection is good, but the lower wall is not. What is any advice in this situation?
1 REPLY 1
Changing the Insulation Intersection Property (IP) to 651 Fixes this situation, but I am afraid that it may create different IP conflicts down the road.
Here is a few of the IP that I have changed (on the right) from the default AC17 residential (on the left).
