I get this Alternative:
Set up Work Environment
. I choose
Standard Profile 12
If you have disabled your Start Box, then take this advice from ArchiCADs Help Function:
To enable the Start ArchiCAD dialog box again, use the File > New & Reset All command.
You will get this choice when you press the
Alt
Button while you click on
New
Ingolf Sundfør, Bricklayer, Author of several Real Life Problem Solving Books for Archicaddicts in Norway.
PC/i7/W11/ArchiCAD 6.5-27
