2007-09-05 12:38 AM
2007-09-05 12:51 AM
Ignacio wrote:it sounds like an issue with the zone stamp that you've chosen for that particular category. go into Options>Attributes>Zone Categories... and check the settings for the category you're having trouble with. if you get error messages there, there is a strong likelihood that you're going to have trouble placing them.
To make them reappear I need to select the zones, change them to some other category, and change them back to their category.
Sometimes the zones decide to display some other stamp (even though they show the correct one in the zone settings, including all stamp parameters and preview).
2007-09-05 12:54 AM
~/archiben wrote:What is baffling is that the name shows correctly in Zone Categories, again the zone settings etc. look perfect (that is: it is loading the object, and it remembers all the object-specific parameters), it is just the floor plan display that disappears or occasionally changes to some other stamp.
which zone stamp have you specified? and what are it's settings?
~/archiben
2007-09-05 01:42 PM
2007-09-05 02:36 PM
2007-11-02 08:04 PM
2007-11-03 06:30 AM
steve_milano wrote:Use some other category (if necessary, create a dummy category) with *the same* zone stamp so as to be able to go back and forth without losing data.
selecting all zones and changing their categories back and fourth and this resets all the zone stamps to the new version except all the data in the new parameter fileds is lost!
