Zones volume calculation, when using profile walls
Gorazd
Hi all. We have encountered one problem, that we cant solve. If I have a zone, stretching to the outside of the wall which is drawn using complex profile (to calculate gross volume) the volume is not correct. The volume of the walls are always deducted from zone volume, regardless of the setting "no affect on zones" in parameters. When using standard walls, volume is correct. Anyone has some solution?
Gorazd Rajh
From AC 6.5 onward, Ryzen 9 5900HS, 48 GB RAM, RTX 3080, Win 11
Miha Nahtigal
Anyone?
BIMquants.comBETA - Quantities and Costs Estimation in Archicad - BETA testers needed.
Miha Nahtigal
Here is a test project which shows the problem:
http://dl.dropbox.com/u/3128804/test.pln
Any solution or comment whatsoever?
When a zone is drawn manually directly over the outside (or reference line(?)) this behaviour happens. Try to offset the zone by just one mm.
Hope it will be fixed soon.
