Zoom In and Dolly
When I zoom in an then dolly around, Archicad dollys around some point somewhere else in space. It doesn't dolly around where I'm actually at. Is there a way to make it dolly around the point where you actually are?
2 Replies 2
Lingwisyer
Guru
If you select an object, it will orbit around around that point.
https://archicad-talk.graphisoft.com/viewtopic.php?t=44840
Ling.
You can also recenter the 3d window by selecting an object you want to edit and use "zoom to selection". After that the orbit should work fine.
