2006-10-05
		01:54 AM
		2023-05-26
		03:03 PM
			Rubia Torres
2006-10-05 02:20 AM
 It stores everything in the Wall Settings dialog, including the height and elevation, but the elevation is always relative to the story you're on. This is where the Info box may be misleading you?
 2006-10-05 02:35 AM
2006-10-05 02:38 AM
~/archiben wrote:Yes this has been annoying me. I would prefer that the syringe picks up all the parameters.
un-reported yet. i'd appreciate some feedback first . .
1. first off, parameters:
using the syringe ('pick up parameters') command in automatic walls takes everything bar the level values (top and bottom heights). should it? or is this operationally correct for automatic walls?
~/archiben
2006-10-05 02:50 AM
Link wrote:ah - there's the problem. unfortunately, is this another case of our "consistency" lecture shooting ourselves in the foot again? although that maintains the consistency with the logic of legacy wall behaviour, maybe that logic needed to be thought through with the introduction of auto-walls? i'm with john - i want the absolute levels to be picked up by the syringe, NOT the relative-to-floor-level . . . and wouldn't that cover relative-to-floor-level for non-auto walls anyway?
2. This is a bug, and yes they are aware of it.glad to hear it - you're sure they're aware this is a distinct aspect of the first 'stretch multiple walls' bug and they don't think that they've already got it fixed? wouldn't surprise me . . .
You? Fed up?? Pinch me, I'm dreaming...yeah. can you believe it? revit here i come . . .
2006-10-05 02:53 AM
s2art wrote:or better still - define a relationship between a wall's top and bottom levels and slab-x/storey-x levels . . . the marquee works great for handling horizontal relationships, but vertical relationships are still awkward, inconsistent and a pain to resolve quickly and efficiently.
"Make automatic wall's base and top heights relative to current storey"
2006-10-05 03:36 AM
 2006-10-05 05:13 AM
Link wrote:no. then it gets too confusing. default logic should work the way you expect it to. it's too easy to propagate an application with settings and options at the greater risk of causing even more confusion and conceding 'ease of use'.
Maybe GS should consider Parameter Transfer Preferences, similar to the Favorite Preferences?
2006-10-05 06:10 PM
Link wrote:Not preference but option. Normal syringe=all parameters transferred. Syringe+modifier=options dialog with include/exclude check boxes.
2006-10-05 07:26 PM
Geoff wrote:I like this idea, Geoff....
