Im having a few problems with getting walls to join up properly in some places were more than just 2 walls intersect.. is there anyways I can get them to clean up and join correctly???
If there is no way you can make it work because it is so complicated, use one or more Polygonal Walls to model that intersection.
You may need more than one because a Polygonal Wall cannot have a hole in it on the Floor Plan so you may have to model it out of two.
Loving Archicad since 1995 - Find Archicad Tips at x.com/laszlonagy AMD Ryzen9 5900X CPU, 64 GB RAM 3600 MHz, Nvidia GTX 1060 6GB, 500 GB NVMe SSD 2x28" (2560x1440), Windows 10 PRO ENG, Ac20-Ac29
I've found that the cleanest intersections occur when the reference line is either centered or if using composite walls moved to the center of the core (Design Menu/Modify Wall/Reference Line - Offset - To Center of Core). But you need to play around with what works in your situation.
Just extend the top portion of the box to the inclined wall on the left. That is how it is going ot be built anyway. Did you ever try to plaster an acute angle that you can hardly reach? 😉
