a mesh area?
how could i calculate a mesh area? in AC8...
4 REPLIES 4
Djordje
The horizontal projection or the real area?
Djordje
ArchiCAD since 4.55 ... 1995
HP Omen
the real area... !
the projection is simple!
pleeease!
Djordje
otylyka wrote:
the real area... !
Select the mesh, go to Calculate, List Elements, Basic. The first Surface area is the top area. If you want to be 100% sure, change the mesh to the surface only and calculate again.
OK?
Djordje
HP Omen
super....!
thank you veeeerrrrrrrrry much!
it's working
