TomWaltz
ac10 fills
Can you tell us a little more? How are they not showing correctly?
Tom Waltz
6 Replies 6
TomWaltz
Is the vectorial scale set the same as it was in 9?
I'm just wondering if there was a bug in the fill transition somehow. The magnification is just a zoom in/out, so it's not that important. I would look at the scale of the fills.... beyond that I don't have any ideas. I know I have brought over several files from AC9 and not had this problem.... yet.
Tom Waltz
There is a note on this issue in ArchicadWiki.
Peter Devlin
Try this link.
http://www.archicadwiki.com/Bugs/Some_symbol_fills_cannot_be_seen_on_the_floorplan?highlight=%28Bugs...
It might be related to what you are talking about.
Peter Devlin
Stephen Dolbee
I also had a problem with AC10 fills. I just printed a section. The siding and shingles printed correctly(vectorial), but the wall fills (%25) printed out like bitmap.
AC19(9001), 27" iMac i7, 12 gb ram, ATI Radeon HD 4850 512mb, OS 10.12.6
SeaGeoff
Ace
The percentage fills have changed in AC 10. They are all a dot pattern now I believe.
Regards, Geoff Briggs
I & I Design, Seattle, USA
AC7-29, M1 Mac, OS Tahoe
Graphisoft Insider's Panel, Beta Tester
Thomas Holm
I thought the percentage fills have always been dot patterns, bit map or not. I don't recommend them. I use grey pens instead. PDFs shrink to a fraction of the size immediately, print faster, and scale better.
