adding molding to wall
I've put in a lot of work on a project, and the wall heights are all set just right (some are 2 story, some not... depends on the situation. Am learning how to work this better, but this is an older project). Guess the point here is, I've missed the opportunity to create an all-inclusive wall complex profile that shows all the moldings, without rebuilding the entire project.
Anyway.
I've created a complex profile for the crown molding only. I've placed it at the correct height juuuust next to the real walls. In the interior elevations, I see the section but NOT the elevation.
In the sections, the distant elevation of the profile DOES show.
I'm confused. I'd really like to see the elevation of the complex profile in the interior elevations please. ???
12 REPLIES 12
Brilliant!
I thought I'd tried that already, but I doublechecked the settings and sho nuff, it were still checked. Totally fixed the issue.
Thank you thank you thank you.
I probably could have drawn all the crown with lines by now, but it's really one of my least favorite jobs. I'm superglad this got squared away.
So glad I could finally be of help to someone else after asking so many of my own questions.
Erika Epstein
They would have changed the molding as soon as you drew the last line
Erika
Architect, Consultant
Mac OSX 10.11.1
AC5-18
Onuma System
