Chris thank you for the advise, but that will not solve the case of railing , or custom shapes .
Gerald ... thank you for that .
but is that true ? a very simple - every day case- and there is no solution for it?
is that real graphisoft ?
I really can't believe that, I mean it even sounds stupid. I still really wish that we are missing something and that all the other gurus have an answer for that ?
I know I can model it in the plan - which is funny because it just work in the plan - and save it as an object and rotate it but do I really have to do this or want to do this? even if I try to apply that profile to a column the result is still cr@p !
I mean do you really graphisoft think you can survive while you are not addressing even the simplest things and try to pretend that you are big and who cares about the small things !
Organic shapes? no who needs that! complicates shapes ( wait I can't really call an intersection of 2 beams complicated
) no who needs that ! sketchup connection ? no one is using it lets stop it . and also sketchup didn't develop any connection for mac ! sorry we can't do nothing about it its their fault .. well guess what? google really don't give a darn about you ! if you want it to work you find a solution !
really archicad today is soooo far from what it takes to impress any one sorry forgot about team work ..right ..so we can share the failure of modelling the simplest things 2 beams for example ?
