bold text with zones
respect 4 all of u,
...my question is: when u create zones, text of zone name, number, floor...itc is displayed bold. Is it possibility to make it regular.
thanks!
2 Replies 2
Jacek
You are right, I tried to change the font and it seems to appear the same. The only way to change the appearance is to use a different font like in the attached view, the lightest one is MM font which can be stretched and manipulated to the desired 'lightness' All others look 'Bold'
jacek lisiewicz
arkhos-tekton, architects
carmichael, ca
Mac OS X 10.15.5
IMac Retina 5K, Intel Core I7
32 GIG Memory, AMD Radeon R9
ArchiCAD 24
I think the text style that is used in GDL for those texts is defined to be bold.
You can look for DEFINE STYLE commands in the Master or 2D Script of the Zone Stamp library object if you know a bit of GDL. Then you can make that value in the DEFINE STYLE command defining the normal/bold character of the text to be parameteric.
