can i create basin tank inside this slab shape ?
Hi everyone can i create elipse basin tank inside specific slap shape like this attached on the image ??
and thanks for the help
12 Replies 12
Yes,you can.
yeah as 2d symbols yes i can do it easily but as 3d i do not know how because we have specific determinations in the library of archicad plumbing fixture as in the image i want to move basin tank middle one in front slightly and make the slab holding 3 basin tank curvy not straight that my question
Steve Jepson
You can use (3) Multi-Basin Counter 15 instead of one and SEO to shape the counter tops. Use the "Edge Visibility in 2D" setting to turn off the side panels as needed to hide the joints.
You are using the best object for this. The sink is adjustable in the counter top using the "Basin Y Distance from Basin Center" setting, or in 3d just select the node at the center and move it to where you want it.
Shot at 2011-09-16
Shot at 2011-09-16
vistasp
Ahmed, I don't have AC15 but it seems to me that the object you are using doesn't have the flexibility you want.
What I would do is make a slab in the shape of the counter (with elliptical holes cut into it) and place individual basins at the correct location.
= v i s t a s p =
bT Square Peg
https://www.btsquarepeg.com
good idea but is there complete eliptical basin in the library i did not find it i find it on three sides eliptical and on the rear side staright this is the case of single basin
vistasp
In the depository, you will find "Villeroy & Boch Sanitary Objects". There are a couple of elliptical basins there as I recall.
Hope the sizes match what you want, though...
= v i s t a s p =
bT Square Peg
thnaks i will try to search on depository i just saw the image right now that Steve did it looks pretty good i wonder how you moved the middle one because when i moved one of the basin the other moves also
Steve Jepson
Use 3 objects not one. Put them together. Then you can move the sinks independent of each other. The objects clean up with each other to make it look like one counter top.
Shown here are the (3) objects and the SEO to shape the counter tops with.
Shot at 2011-09-16
Great, Great effort help i like this i understand now that you used (3) Multi-Basin Counter 15 and you choose on number of basin and then you copied it but Does 2d representation of this basin sinks correspond with solid element operation because i heard before that lines of effected targeted element is still the same even after solid element operation
