heathldesign
can't get railing changes to stick
Good day,
yet another bug me thinks. i have been trying to edit a railing, but the changes don't stick. quit and restarted, didn't make a difference. i've tried editing it in edit mode from the 3D window, in 2D in edit mode, and in 2D with the railing tool settings dialogue. i make the changes and click OK. but the railing segment remains unchanged. so far the only way to do it is to delete it and build a new one exactly the way i want then place it. very inconvenient and quite the pain in the A. see the video
MAC Studio 2022 M1 Max, 32 GB RAM, 10 cores, AC27 5030 Apple Silicon USA Sequoia 15.3. AC 27, 6000 USA
32 Replies 32
Botonis
Mentor
Hi @Kornel Beleznai.
Is there any time frame for this bug to be fixed.
Both 27 and 28 face still face the same issue.
The whole idea of the new hotfix policy is to fix as fast as possible small issues as soon as they are detected.
Thank you for you support.
Botonis
Mentor
@Kornel Beleznai
Greetings.
This bug still exists in 29. Everytime the file is opened the railings have different settings.
We have at least three Archicad versions with the same problem.
Kornel Beleznai
Hi @Botonis,
Sorry for the delay. Yes, unfortunately, this issue is still with us. The last update from the related Product Manager implies that even though it seems to be a small issue, it is not an easy fix.
That being said, I highlighted to them that the issue keeps getting reported here, in this Community thread. Hopefully, they will consider raising the priority of this defect, however, I cannot promise anything at this point, sadly.
Thank you for the understanding.
Beleznai Kornél
Senior Technical Support Engineer
