cannot drag a node of wall corner to a snaoed position
hello, I drew a wall which corner a bit deviates from the grid line (not snaped maybe) , how can I just move the node of this wall coner to thecorrect position? thanks
1 Solution
Guru
Just disable groups (alt + g) then use the stretch option of the node?
Ling.
Go to post
3 Replies 3
Guru
Ling.
Start to drag the node, move approximately horizontal and hold SHIFT to constrain it horizontally (or you can use snap guides if you have them turned on).
Then snap to the orange guide line or match the other end of the wall if that is in the correct position (keep holding shift to constrain horizontal).
OK thanks Barry, and Ling
