2005-11-28
04:57 PM
- last edited on
2025-01-29
03:34 PM
by
Molinda Prey
2005-11-28 10:17 PM
2005-11-30 07:43 AM
marta wrote:You have a pretty tricky situation here. The wall accessory will not (AFAIK) allow you to intersect the wall as you wish. The best I can think of (not knowing your level of expertise) is either to make separate elements for plan and 3D (fills & lines in plan, SEO's for a 3D element), or to make a library part combining the two functions into one element. Unless you are comfortable with GDL (or have the time and interest to take it on) the former solution is probably best.
ok, i think this will work. i used the accessories, canted wall to make the canted wall. here it is in plan. the canted wall is the one going up and down the screen (the big blue mark). i need that furthest end to be filleted with the wall that coming in to it (there is an empty opening at the joint right now). i have to post a picture of the roof/wall separately. any ideas?
2005-11-30 07:50 AM
marta wrote:Did you align the edge in plan or in section/3D? There can be a discrepancy since the roof is placed by its lower surface but displays the upper one in plan. I recommend using SEOs (Solid Element Operations) instead of "Trim to Roof" unless you are having problems with the SEOs. They can get troublesome in complex situations, but yours does not look overly complicated.
second, here is the roof that i put on the canted wall. the outside edge of the roof is lined up with the outside edge of the cant. i did a trim to roof and this is what i got from that. any ideas?
2005-11-30 04:02 PM
2005-11-30 04:52 PM
2005-11-30 05:23 PM
2005-12-01 12:43 PM
2005-12-02 09:00 PM
