Yoavzarc wrote:
...but its strange that your not that familiar with these kind of plans.
Thanks
Yoav.
We are familiar with these kinds of plans, but the majority of ArchiCAD users here on ArchiCAD Talk are using ArchiCAD as Architectural Design Software not as Manufacturing Software. Architects are for the most part concerned with producing construction documents for What to build, not How to fabricate it.
In the case of Cabinet Shop Drawings we are typically satisfied to design the layout, and are finished with it using a note that says "See Cabinet Drawings by Others". Your are the "others".
There are several reasons for this.
It may be a waste of time to detail the joinery, door profiles, etc... when it will all be fabricated with CNC machines that need a specialized or even proprietary software files to run.
The majority of casework is prefabricated. We may add the manufactures number for the cabinet box, but the manufacture has no interest in some architects idea about how the cabinet should be put together. The fabrication plans need to be specifically for the equipment and computers used in the specific shop where it is being made.
Even small low tech Custom Cabinet shops have certain standard fabrication processes, specialized saws, jigs, and methods for the sake of efficiency. We rarely know what shop will be making the cabinets, let alone how to make useful shop drawings for their process and equipment.
Architects don't want to be bogged down with cabinet shop drawings. If you choose to make them, even if using typical prefabricated cabinets you will be stuck for days trying to help the client decide which side of the drawer the spoons go on, where they will put cookie sheets, etc... we have a building to make plans for.
ArchiCAD is a great tool for fabrication plans, it's just that very few ArchiCAD users here are using it the way you are asking about.
If all of my work was making cabinet fabrication plans I might choose one a manufacturing software program like this one.
http://www.2020technologies.com/en-us/manufacturing/2020-shopware/
Both of these carpenters need Architect shop drawings like another hole in the head.
