2025-02-22 11:21 AM
my chain wall icon and curved wall icons do not open after update from 27 to 28 any help to fix this
Solved! Go to Solution.
2025-02-24 08:19 AM - edited 2025-02-24 09:07 AM
If you mean the pop-out does not show, try holding for a fraction of a second when you click the button.
A quick click will not work.
2025-02-24 03:33 AM
Check if your toolbars are setup properly? You could test with the default work environment.
2025-02-24 07:38 AM
itried that, its set up as default settings, also tried looking at layers to make sure they were set up correctly.
2025-02-24 08:41 AM
Can you press G to cycle through the options?
2025-02-24 03:00 PM
yes this works thank you, didn't know I had to hold the button, 27 just clicked
2025-02-25 01:01 AM
It has always been like this as far as I know - I just checked 22 and it is the same there.
Just checked 27 as well and it is the same for me there too.
Maybe it is a few milli-seconds slower in 28 that is making the difference.
It is what a call a 'long or slow' click rather than rather than a 'short or quick' click.
The speed must have changed because others have been caught out as well.
