Saturday
my chain wall icon and curved wall icons do not open after update from 27 to 28 any help to fix this
Solved! Go to Solution.
13 hours ago - last edited 12 hours ago
If you mean the pop-out does not show, try holding for a fraction of a second when you click the button.
A quick click will not work.
17 hours ago
Check if your toolbars are setup properly? You could test with the default work environment.
13 hours ago
itried that, its set up as default settings, also tried looking at layers to make sure they were set up correctly.
12 hours ago
Can you press G to cycle through the options?
6 hours ago
yes this works thank you, didn't know I had to hold the button, 27 just clicked
