chain wall doesn't work after update
mobilman
my chain wall icon and curved wall icons do not open after update from 27 to 28 any help to fix this
If you mean the pop-out does not show, try holding for a fraction of a second when you click the button.
A quick click will not work.
6 REPLIES 6
Guru
Check if your toolbars are setup properly? You could test with the default work environment.
itried that, its set up as default settings, also tried looking at layers to make sure they were set up correctly.
Guru
Can you press G to cycle through the options?
yes this works thank you, didn't know I had to hold the button, 27 just clicked
It has always been like this as far as I know - I just checked 22 and it is the same there.
Just checked 27 as well and it is the same for me there too.
Maybe it is a few milli-seconds slower in 28 that is making the difference.
It is what a call a 'long or slow' click rather than rather than a 'short or quick' click.
The speed must have changed because others have been caught out as well.
