changing attributes of multiple object types
I find that I often want to select a collection of objects (such as lines, arcs, & polylines) amd change their attibutes - pen layer, linetype. IT appears that AC will only change one type at a time which so I have to select each type separately to change them.
Is that the onbly option or is there a way to make AC apply the changes to everything selected? thanks.
3 Replies 3
Mats_Knutsson
Mentor
Hi
Mark the items and then through the menu: "Edit->Element selection set->Edit selection set" will help you a little.
/M
AC 25 SWE Full
perfect! that does it. I hoped there was a way somehow. you just saved me much time and frustration - thanks!
Stress Co_
Or use the "edit selection set" shortcut: (Hammer in a square icon, in the Info Box).
Marc Corney, Architect
Red Canoe Architecture, P. A.
