rotating whole project
Is there anyway to rotate a whole porject as once ?
19 Replies 19
Bob Moore
I'm on version 9 and all you have to do is use your cursor to select the whole project then use the rotate tool in the edit menu to rotate it to the desired position. I'm not sure about AC10.
AC 7 - 29
iMac 27"
Mac OS Sonoma 14.0
3.1 GHz 6-Core Intel Core
32 GB 2667 MHz DDR4
Radeon Pro 575X 4 GB
Jere
Make sure you have the marquee tool set to the thick line marquee (all floors option) in the info box.
ArchiCAD 26; Windows 11; Intel i7-10700KF; 64GB RAM, GeForce GTX 3060
Also have all the layers turned on so that nothing is left in its original position.
TomWaltz
You can rotate an entire model with all its plan content, but the 2D content of elevation/sections and detail will not rotate. The next time you open a section and rebuild it from model, the building will have moved from its original location and any 2D content will not align any more.
Tom Waltz
My thick Marquee tool that is supposed to select items on all stories doesn't work. It only selects things on the current story (just like the thin one). Is there some preference setting or something I am missing??
When I need to rotate a project I have to do it floor by floor then items that show up on more that one floor get rotated more than once if I am not careful- very time consuming.
Stress Co_
...and don't forget to unlock those layers you locked.
Marc Corney, Architect
Red Canoe Architecture, P. A.
Mo,
You need to go surfing with Greg Heitzler ( g.h.design )
http://archicad-talk.graphisoft.com/viewtopic.php?t=10672&start=20
Stress Co_
s2art wrote:
Mo,
The waves at Bonny Doon Look way sicker than Oak Bluffs.
Must have been a North Shore day.
Bonny Doon, Bonny Schmoon
Oak Bluffs Rules!
