colors in 3d window
transfer of walls from 14-15 all is just white in 3d window. My doors and base and crown should be gloss white and walls should have a color.
Is there some new setting buried somewhere?
1 REPLY 1
Did you just open the 14 file in 15?
If so the materials (colours) should be as they were in 14.
If you copied & pasted the walls then the material attributes are probably different in the 2 files.
What method did you use?
