complex profile for wall - baseboard
what is the best way to add a baseboard trim to a wall? i would like to use my predefined composite walls, and attach the baseboard profile i created, but the wall is replaced with only the baseboard when i apply the profile to the wall.
any suggestions?
5 Replies 5
TomWaltz
I tend to just draw a separate wall for that.
I tried making them part of the profiled walls, but the extra line around the walls (for the base below) was confusing everyone. I tried setting walls to "Cut Only", but then walls that needed to see what was below did not work.
Tom Waltz
if i draw out the whole wall, i lose all the quantity information on any walls with baseboards.
does anyone have experience with CadImage Profiler? is it any different?
thanks in advance.
What about the interior accessories / wall accessories.
TomWaltz
LINZ wrote:
if i draw out the whole wall, i lose all the quantity information on any walls with baseboards. .
You do? Why is that? You can create a list of the walls you use as baseboards.
I do... my thoughts are not fit for polite company. Suffice it to say I would not use them. This is not unique to the CADImage Accessories. It's for the Archicad accessory system in general.
Tom Waltz
re: quantity info lost ...
im referring to composite info - wallboard area, etc.
