I was thinking about how to do this intersection.
Because yes, we can increase the priority number of the Plaster to be stronger than the brick, but the horizontal brick still won't extend to the left brick skin of the vertical Wall.
So what I did is I created another brick skin into the horizontal composite. It is a zero thickness brick skin (it IS possible to set zero for skin thickness). This way both horizontal brick skins will connect to a vertical brick skin.
The only thing is that there will be a horizontal line at the top of the right brick skin of the vertical Wall, but we can place a fill over it. That is the closest I can get to it.
The other solution would be to model this Wall corner using a Profile and place that Profiled Column in the corner.
EDIT after further discussion: As it turned out zero thickness will not work in 3D, but a very small value like 0.1 mm or even 0.01 mm will.
