Yes if all the skins are the same BMs then they will simply trim with the first skin that is the same or a stronger BM and then there will be nothing left to trim the other skins which may be weaker.
So I would not have the same BMs in different skins of the same wall.
I would have an 'inner brick' BM and an 'outer brick' BM with the outer skins generally being stronger.
The same with the plaster - 'inner plaster' and 'outer plaster'.
Maybe this is why I have never really had any problems (apart from the fact I generally don't model the finishes and cavity insulation anyway).
I do have double brick walls that are the same brick inside and out but the outside leaf is always stronger and I actually make my cavity the strongest of all as I always want my cavity to be continuous.
