ā2011-10-11
07:50 PM
ā2023-05-24
01:03 PM
Rubia Torres
ā2011-10-11 08:30 PM
ā2011-10-11 08:40 PM
ā2011-10-12 02:59 PM
ā2011-10-12 05:38 PM
ā2011-10-12 06:28 PM
ā2011-10-13 11:17 AM
dasneboja wrote:if I SPACE+click slabs into my rooms lines that bother me goes to the wall sides not to the door frames and I get two of them on both sides instead od just one. If I have different floor types I can set doors to show treshold and I get that line, or I can draw another that slab with different height in that room. It is not often situation that you have a lot of different floor types.
@mzex
Main issue with your method is how to model different type of floor finish?
especially with different heights...
Lines that bothers you, are actually connection lines of two different floor type, so they should be there...if floor finish is the same, then use one finish slab for multiple rooms...
ā2011-10-13 11:22 AM
vfrontiers wrote:first part of your post I find unimportant since I don't do any hatching on my floor plans, but if you like that no one said that you can't draw another slab in the room that has different finishing.
Also important is the ability to represent different FINISHES in plan.. With the ADDED floor finish SLABS, you can have different FILLS and create a nice looking PRESENTATION PLAN without a bunch of extra 2d fills.
AND.... If you use your structural slab as TOP OF SUBFLOOR, you can place LEVEL DIMENSIONS based on your structural slab (turn off FINISH FLOOR layer)...
ā2011-10-13 11:51 AM
ā2011-10-13 02:43 PM
dasneboja wrote:I don't have problems with calculating volume of the concrete, and finishes are calculated in m2, so I get that from zones.
Best thing about your method is that works fine for you...![]()
If you're ok with tracing custom levels whenever you change something,
and not having right volume of your slabs (for BOQs) that's ok with me
SEO will slow you down on large scale project no matter how powerful you hardware is...
