‎2011-10-11
07:50 PM
‎2023-05-24
01:03 PM
Rubia Torres
‎2011-10-13 02:51 PM
dasneboja wrote:and what happens when you make a cross section through wall inside of the the building?
@mzex
if floor finish is the same, then use one finish slab for multiple rooms...
‎2011-10-13 03:36 PM
‎2011-10-13 11:30 PM
dasneboja wrote:perfect in section, but not in floor plan. you get two lines on every side of the wall.
You misunderstood my suggestion,
My finish slab is single slab drawn by inner contour line of the walls,
and it goes trough door to other room with same finish(if there is no threshold),
so it is perfect in section, no SEO,
‎2011-10-13 11:42 PM
‎2011-10-13 11:53 PM
dasneboja wrote:under schedule you have two major folders. one is element and the other one is component.
How do you get slab volume out of zone?
‎2011-10-14 10:09 AM
‎2011-10-14 10:24 AM
mzex wrote:I was asking for volume out of zone...dasneboja wrote:under schedule you have two major folders. one is element and the other one is component.
you should use component to get volume out of composite.
here is picture with that.
everything is possible in archicad if you spend some time to discover diverse features.
‎2011-10-14 01:18 PM
dasneboja wrote:it depends on my mood. If I have a lot of time that I SEO all the slabas, if I am in the hurry I SEO only those visible in sections.mzex wrote:I was asking for volume out of zone...dasneboja wrote:under schedule you have two major folders. one is element and the other one is component.
I do use schedule/component to get volume out of slabs,
and that is one of the major reasons why I use "two slabs method"
cause I have in model everything exactly as it should be built...
One more q for u
Do you SEO all slabs and all walls, or just one shown in sections?
