contour line crossing building outline
I created a slopped terrain using mesh and polyline. Then designed a building on the slope. Some part of my building is below grade so I used SEO in order to extrude the dirt. After creating the building, the site plan drawing in my view map has the mesh polylines crossing onto the building. I want to know how to make the mesh polyline stop at the building outline on my site plan and first floor plan.
Thanks!
6 REPLIES 6
Dwight
The cheapandnasty solution: Mask the contours with a solid white fill.
The professional way: cut a hole in the mesh to match the building. Fill in under the building with a new flat-top mesh.
The complete way: reconfigure the mesh.
Dwight Atkinson
Thank you for the fast response. I think I managed to solve this by cutting a whole.
Dwight
To maintain the integrity of your model, just cutting a hole leaves a void under the structure. If you don't fill it with something, the building will fall all the way to China [or whatever is on the opposite side of the world from you]. It is a problem in section…
This is why I prefer the SEO method, giving your floor slab an opaque fill to hide the contour line.
Dwight Atkinson
Or it will just simply fall through the whole Earth and out into deep dark space.
Bob Moore
Maybe to Middle Earth?
AC 7 - 29
iMac 27"
Mac OS Sonoma 14.0
3.1 GHz 6-Core Intel Core
32 GB 2667 MHz DDR4
Radeon Pro 575X 4 GB
And there the magnetic field should be equal along with zero gravity and hence lock it in stable middle earth forever and ever?
Talk about a room with a VIEW.
