convert jpg plan to archicad
dear sir
i have jpg paper plan iwant to convert it to archicad and redraw it
how to do this
regards
5 REPLIES 5
File - External content - Place external drawing
Good idea is to place it on a separate worksheet
and then trace reference it
Please add signature with software and hardware you use
thanks dasneboja
This is exactly what I did, but Im new user of Archic and I do not know how I work .... i trace it by choosing wall tool but the tracing become not straight
so i stop working.
Can you explain to me exactly step by step process
I would be very grateful to you
obotalal wrote:
thanks dasneboja
so i stop working.
Hi Obotalal,
It's not too difficult, try to search it in HELP first (most of answers for my questions there)
file:///C:/Program%20Files/Graphisoft/ArchiCAD%2015/Help/Files/wwhelp/wwhimpl/js/html/wwhelp.htm#hre...
and chose Place Drawing from External Application
I'm not sure I understood you but if you place an image of plan (JPEG, PDF,...) you can't snap to its points. You can do it if placing DWG file.
HTH
obotalal wrote:
dear sir
how to do this
regards
Copy .jpg then paste into ArchiCAD. Next you need to stretch or resize the .jpg to scale. Find some thing in the .jpg that you know the size of. Perhaps a dimension, door, something.... draw a line that length. Move the .jpg to match one end of that line. resize the .jpg to fit the line. You may need to rotate the .jpg some as well. Send .jpg to me if you like. I will sretch it to scale for you and send it back. What scale would you like to draw in ?
When you are drawing walls hold down the SHIFT key to keep walls either horizontal or vertical (if this is what you mean by straight) in plan.
