copy and rotate on path
hi all
I have railing how can I copy object on curve path like spline and make object rotate to align path (follow or bank in other software)
3 REPLIES 3
Hi
If I understand you correctly, you want to create an Object. This object will consist on a Profile following a path, a Spline in this case.
This part can be done easily using "complex profiles" and walls for the path.
The second part, rotating the profile along the path, is not possible with the tool you have available on AC at the moment. Although you can try some advanced GDL scripting, there is a "command" that does something similar (Sweep) but scripting GDL can be very frustrating.
I can suggest you a workaround: Built your object on a different software with better free form modeling capabilities (3D max, Maya, Bonzai3D, and even Sketch Up). Then export it as a 3DS file. Load it from ArchiCAD converting the 3DS into an object.
I hope this can help.
Regards
Nando
Nando Mogollon
Director @ BuilDigital
nando@buildigital.com.au
Using, Archicad Latest AU and INT. Revit Latest (have to keep comparing notes)
More and more... IFC.js, IFCOpenShell
All things Solibri and BIMCollab
thank you but I hope to do it in ac to have correct section in it I will try in gdl
thank
I try found nothing in gdl or in ac ??
