corner windows, skylights etc
Corner windows & skylights are two 'tools' not showing up. However, when I try to upload them in the plug-ins manager I get this reply: corner windows not up-loaded, can only be up-loaded into archiCAD from start.
What's this about? How do I get the corner windows tool active?
Rather urgent.
many thanks
6 REPLIES 6
It seems like these tools were already loaded with my copy of AC. Put the plug-in's in the AC "addons" folder and they will load automaticly when you start AC. Good luck!
they (the plug-ins) are in this folder and all load up except for corner windows and skylights. very frustrating!
Aussie John
Personally I dont think you are missing much
Cheers John
[/size]
well if my client/boss wants corner windows, then I need them.
Aussie John
a window in each wall of a corner seems to do something similar
Cheers John
[/size]
__archiben
do a "new and reset"
they should then be showing up as fly-outs from the door/window tool (can't remember which shows by default).
if they don't show, my guess is something isn't installed correctly and you'll have to do a clean install of archiCAD.
for what it's worth, i'm with john - i don't think that you're missing much: they are quite temperamental, and require a lot of fiddling to get right. be careful after making changes to them too - they often break back into two windows if a parameter is slightly arwy!
~/archiben
b e n _ f r o s t
