2004-07-11
10:50 AM
- last edited
2 weeks ago
Molinda Prey
2004-07-11 12:44 PM
2004-07-11 07:44 PM
ihsan wrote:You can't, in any software.
since the building should be created by floors..how can I for example create a 60 floors model without having created a heavy file
2004-07-12 06:49 AM
2004-07-12 12:58 PM
ihsan wrote:at a very, very early masterplanning stage, you may want to make it out of one 'block' - simply to show massing. but otherwise, i think the answer to your question is yes - still work by floors: keep thinking ahead about what you are going to need to work with at the later stages of the project.
thanking you all
I need to make this clear ..... I am separating the project in stages ...so that during the proposal and massing stage the inner typical floors and details are neglected..
then in this case normallt how should I work...still by floors or only by mesuring hieghts to locate levels and external floors effects...to give the cloasest look of building..
regards
2004-07-15 11:29 PM
~/archiben wrote:Actually I would think that you should use that approach only if your floors differ. Your primary way of doing this (in my limited experience) is to use Modules. That way if your standard floor changes, you only need to change your module and the whole building would get updated automatically.
if the external skin of your building (the bit that you will be modelling for the first phase) is very similar throughout its height you can use the copy/paste commands found in the Options>Stories>Storey Settings... dialogue to do most of the work for you: simply model the basic floor components as necessary and then copy/paste them as you create new storeys.
2004-07-16 12:57 AM
2004-07-16 03:06 AM
2004-07-16 09:01 AM
Djordje wrote:Hi Djordje,
For example, a full 100000 sqft villa with full interior at Emirates Hills
2004-07-16 09:26 AM
Naftali wrote:It is, let's say, upmarket mid range. Mid range is usually half of it, with less finishing. Average house plot is not less than 100 by 100 feet - that is what the governement gives to any newly wed Emarati couple to build the house on.Djordje wrote:
For example, a full 100000 sqft villa with full interior at Emirates HillsAnd I suppose this is considered mid-range housing where you work ?? You didn't happen to have anything to do with any of Saddam Hussein's palace projects, did you ??
Is there anyway we could see this project ???
