creating a ruin structure?
Hi all,
\have been trying to figure out how I could possibly create a few walls slabs and columns which are meant to be part of a concrete ruin. So egcrubmledd edges and fallen off in chunks exposing the reinforcement etc [hope that makes sense].
Anyone have any tips or ideas on how to go about something like that?
8 REPLIES 8
Make the slabs and columns and convert them to morph? Then you can tweak the edges. Will be a little tedious...
...Or make a morph of the inverse shape of the damage, then SEO it away from any slabs, columns etc. Put it on a separate layer and turn it off to see the effect. Note that you may not see the effect on plan, just in the 3d window.
Place bits of rebar in the slab using the beam tool with a circular custom profile.
You might consider a mesh.
Create a mesh that surrounds the elements you want
to reshape. After modeling the shape of the mesh to
conform to the shape you want to remove
change the mesh to a negative skirt, meaning extend the
skirt upward by giving the skirt a negative value.
Then perform a SEO with upward extrusion.
You can create any number of meshes to suit your purpose.
With suggestions by others on this thread you should be able
to model what you want with the usual caveat about the 2D appearance.
Peter Devlin
vfrontiers
Assumption #1: You want the crumbled items to ALWAYS be crumbled…
If so, then take all the advice given… and where SEO's are used… take the cut elements and CONVERT TO MORPH… then you will have a decent 2d representation of the RUIN.
Note that by converting to Morph, you no longer need the CUTTER ELEMENTS (though you may want to keep them to cut other elements later)..
Duane
Visual Frontiers
AC25 :|: AC26 :|: AC27
:|: Enscape3.4:|:TwinMotion
vfrontiers
Peter Devlin
Peter,
Learn something new everyday! I had no idea the negative skirt would do that… In fact I was ready to question it and then I tried it… I could have used this about 10 years ago!
Duane
Visual Frontiers
Peter Devlin
Peter,
Me too. Just used this technique to model a swimming pool with a sloping bottom. Could have used a Morph too I suppose, but this works well. Thanks Peter!
Hello Duane, Hello Stuart,
Great to hear from both of you.
Thank you.
Stuart, I made a GDL object once of a swimming pool very like yours
but not as flexible as yours because you can change the mesh shape
very quickly.
I must confess the mesh tool is my favorite of all Archicad tools.
One can create precisely controllable plastic forms. When it first came out
in AC 6 I studied it extensively. I am glad you guys know how to use it.
Many AC users do not, I wish they did.
Thank you,
Peter Devlin
PB
Ahhhh.......wish I'd known this when painfully modelling organic pool forms over the last few years!
.......many thanks for an invaluable tip.
AC28. Twinmotion.
16" M1 Max MacBook Pro 32GB, Apple Studio Display, MacOS 15 Sequoia
