creating vertical weatherboards..
i should make it known that i am a relatively newcomer to archicad, so the answer could be in front of me - i would just not know it.
i was wondering how one might go about creating wall profiles with vertical weatherboards visible in 3D. I noticed that the standard walls accessories do not accommodate such a thing and it would be quite an exercise to use complex column profiles when it comes to windows and openings.
Any help would be appreciated..
18 Replies 18
Szabolcs Miko
Actually, I just tried, it would be also possible and better to use the new CW tool in AC22 (it would be a bit more elaborate but still you can also make it with the old Tool if necessary).
Check the attached pictures. I used two curtain walls, why? Because we have to think about the frames intersecting with each other, and it's also better performance wise.
Szabolcs Mikó
Manager, Customer Support
Karl Griffith
I think this is the thread for the GDL object
http://archicad-talk.graphisoft.com/viewtopic.php?t=58432
ArchiCAD 22
Win 10
Carstenem
I contacted Heimo and he gave me this link. It's a AC21 file including the library part which will be associated to the walls you select through - design extras - Accessories - wall Accessories.
There is some stuff missing in the download file as it is not a .pla just ignore, download link: https://www.dropbox.com/s/kf0ya8nxvww3nb2/Fassadenpaneel-Teilungen%208.bpn?dl=0
Video on how to use it ( in german but it's pretty straight forward, you can follow without sound )
To get it into your ARCHICAD file and use it just save it out of the library from the download file then open your ARCHICAD file and load it in, see image attached.
MANY THANKS TO HEIMO MOOSLECHNER !
Cheers Carsten
Carsten
www.asmtechbase.com
https://www.youtube.com/asmtechbase
AC 3 to 26 -Windows 7 - 24GB - 8core 4.4Ghz
Guru
Szabolcs wrote:
We can also create a cladding using the Railing Tool
The issue with doing this is when you come across wall openings. In these cases, you will need to convert your railing into a morph then SOE it as I do not recall being able to SOE a railing object. At this point, using a railing becomes less of a convenience than using a Complex Profile straight.
Can you apply a profile to the CW panel? Or are you using the frames as your cladding surface?
Ling.
Szabolcs Miko
In AC22 we can use profiled panels, but that's for the edges not the panel itself.
HOWEVER, if the Panel uses a Surface which has a vectorial hatching and a texture with a proper bump and displacement channel, we could reduce our number of polygons and achieve the same result.
Szabolcs Mikó
Guru
I believe the aim was a way to create cladding what can be easily detailed, in which case the use of a texture does not meet the requirements. In the grand scheme of things I might be better to leave the model using textures and just detail it manually in 2d due to model complexity.
Ling.
Yes.
Even if modelled correctly in 3D, the details from that model may still not be accurate enough.
Plus depending on how much panelling you have and how detailed it is, you will be adding a lot more polygons into you model size.
If you can get away with a texture for presentation and a hatch for documentation on your surfaces, then i would recommend that, and make your own details.
Carstenem
BIM Barry BIM ! Just kidding that's probably the way to go to make life easier in documentation.
Carsten
www.asmtechbase.com
Guru
Carstenem wrote:
BIM Barry BIM !
All about the information, less about the model. The layer/wall representing your cladding can contain all the required information. Still BIM!
Ling.
