2009-02-20
01:25 AM
- last edited on
2023-05-25
06:27 PM
by
Rubia Torres
2018-10-04 03:58 PM
Szabolcs Mikó
Manager, Customer Support
2018-10-04 06:17 PM
2018-10-05 12:10 AM
2018-10-05 03:17 AM
Szabolcs wrote:
We can also create a cladding using the Railing Tool
Szabolcs wrote:
Actually, I just tried, it would be also possible and better to use the new CW tool in AC22 (it would be a bit more elaborate but still you can also make it with the old Tool if necessary).
Check the attached pictures. I used two curtain walls, why? Because we have to think about the frames intersecting with each other, and it's also better performance wise.
| AC22-29 AUS 3200 | Help Those Help You - Add a Signature |
| Self-taught, bend it till it breaks | Creating a Thread |
| Win11 | i9 10850K | 64GB | RX6600 | Win11 | R5 2600 | 16GB | GTX1660 |
2018-10-08 01:58 PM
Szabolcs Mikó
2018-10-09 03:12 AM
Szabolcs wrote:
HOWEVER, if the Panel uses a Surface which has a vectorial hatching and a texture with a proper bump and displacement channel, we could reduce our number of polygons and achieve the same result.
2018-10-09 03:19 AM
Lingwisyer wrote:Yes.
In the grand scheme of things I might be better to leave the model using textures and just detail it manually in 2d due to model complexity.
2018-10-09 03:53 AM
2018-10-09 08:09 AM
Carstenem wrote:
BIM Barry BIM !
