Starting August 6, 2024, TLS 1.2 will be the minimum required protocol version for Graphisoft products and services that require an online connection. License Manager Tool update is required on Windows. Learn more…
2015-03-2607:29 PM - last edited on 2023-05-2302:27 PM by Rubia Torres
I would like to curve the upper portion of a roof into a vertical wall (of a cupola) using the same materials. I have trouble controling the shell tool and was looking for suggestions on the best way to do this. Thanks for any help with this :?:
