#d modelling in archicad
A lot of general questions here, but how can i achieve a curved bridge with handrail to match and vertically curved shapes? Is this possible in Archicad?
8 REPLIES 8
you can do this with trussmaker (in extras menu)
bill
Not excacly.
If the curve is on one flat layer yes.
But if its a winding road (have curves in both x-y axis) then is very tiring
TomWaltz
Archicad is notoriously weak in curved modeling of complex forms. In some cases you can work a little magic and get the desired results. Other times you cannot.
Tom Waltz
if the bridge is curved in both plan and height then, no, trussmaker won't work
a combination of the 'curved ramp' and 'spiral' objects in the library might work
bill
TomWaltz
The other alternative is some custom GDL programming, but I doubt it would be cost effective for a single use,
Tom Waltz
Rakela Raul
the perfect software for that type of project is GEOPAK...
in this case 'geopak bridge'...you will find it in www.bentley.com
check our web page www.bhaengineers.com
all those bridges an interchanges are a good show
MACBKPro /32GiG / 240SSD
AC V6 to V18 - RVT V11 to V16
Djordje
As always:
- ArchiForma, GDL Toolbox
As of recently:
- MaxonForm
Djordje
ArchiCAD since 4.55 ... 1995
HP Omen
Hello
You can also try the "Ponte FL" Object of CU Mirco in the "ArchiCAD 8" section, Download of his site 3DSmile http://www.3dsmile.it/index.php accessible after free registration
HTH
