2004-08-16
07:26 PM
2023-05-26
11:46 AM
Rubia Torres
2004-08-16 07:45 PM
2004-08-16 08:10 PM
tprokop wrote:
Not sure how much you want to change on it but one way would be to change the values in the "Master_gdl" to a number that is high enough to cover the scales you use. This object assigns the T_ value which the doors use to determine the changing point of scale sensitivity. By changing the T_ value, the doors can default to the "Scale Sensitive" option but as long as the T_ value is greater than the scale value, they will come in at the detailed option.
The only other way I know of would be to open all the door library parts and change their defaults.
Hope this helps.
2004-08-16 09:01 PM
2004-08-16 09:29 PM
2004-08-17 01:13 AM
Archibot wrote:
how do you change the default?
i really only use one door. so if
i just change that one i should be
set!
2004-08-17 05:52 PM
2004-08-17 08:20 PM
Mike wrote:good idea! i will try that!
Would using favorites help or are you looking for a different alternative.
