fevzi19
different roof coverings
I'm covering the roof with tiles, but I want to cover some surfaces with clear roofing felt. Is there a way to do this?
2 Replies 2
Duplicate your roof.
Cut a hole in one where you want the translucent sheets.
Crop the edges of the other so it is only the size of the hole and change the material.
Now move that one to fill the hole in the other.
Guru
Thinking about integrating with roof tiles, can you not get polycarb and glass roof tiles in some places? Not sure how you would deal the structure and any shadow casting from it... If you could diffuse it enough to not see it.
