different story heights
Hi, I have to draw an existing building on archicad (actually, my first "real" work on the software).
The problem is that the different parts of the building don't have the same height.
What is the best way to work on my case?
ground building 1/ ground building 2 / 1rst stage building 1/ 1rst stage building 2...
or
ground floor/ 1rst stage /2nd.... with differents slab heights (more than 1m difference) ?
Thank you!
Hi
You have to define yourself what is the main story level you choose to follow. Then the rest to follow.
For example, sometime you have to manually move your slab to the desired level....
Let me know if you need more help with details....It's not complicated but a bit tricky.
Cheers
Thanks !
