dissapearing floor plan please help!
Hi
im rather new to archicad 10 i am using windows xp as OS
for some reason in my plan my lines dissapear, i know the objects are still there because when i highlight them they are visible.
and they are also there in 3d view
i at first thought it was my floor plan cut plane but as is in the attatched jpeg i believe this is not the reason
thank you for your help.
DunX
12 REPLIES 12
They are visible once i select them i dont understand please help..
i just noticed something else,
when i draw a wall and take the section the wall has dissapeared in the section also
the levels are switched on, i believe the levels are correct.
the wall selected in section
anybody have any idea??
Aussie John
You probably have the wall settings beyond the range of the storey settings.
If the wall is set to automatic it will be invisible if outside the range of the storey. Section lines can also do this.
Cheers John
[/size]
is it possible that my archicad 9 edu could be the reason, what if i uninstall it?
and it was not set to automatic and it was within the range?
actually i think you are right because when i place the wall it shows up
when i place the roof and then elevate it is then when it dissapears how do i fix it?
Hi
i am almost certain it is a bug after playing around with it for about 3 hrs!
i will call graphisoft and report it tommorow.
what is the usual procedure for reporting bugs is there a section on this forum?
Aussie John
change the wall settingso it says not "automatic" - Unfortunately i cant remember the exact menu names
Cheers John
[/size]
DunX wrote:
Hi
You need to report bugs to your local reseller, who will forward it to Graphisoft.
