door and window numbers
Hey I was wanting to display the window and door numbers on my floor plan and then on the bracing plan - to show the doors but not have the door and window numbers on there. I have used Document -> Set Model View -> Model View Options -> and clicked the with markers box to show the numbers and used the id section in the tags and categories in the door settings. but how do I not show this on my bracing plan.
Eduardo Rolon
You will need to create one MVO with ID's on (which you did) and another with them off then you assign them to the correct views.
Eduardo Rolón AIA NCARB
AC27 US/INT -> AC08
another Moderator
Thank you it worked. I didnt even know that was possible to do that haha. You made my day a lot easier.
