I have been running into many instances of strange behavior of door and window trim (and sometimes frame) with the 12 library, even with proper opening reference lines. I've sent a file to GS with a number of examples, but I think it would be helpful if more people posted problems they are having with complex profiled walls here.
With proper reference lines and with wall embellishments at base and crown, I found that in some cases, doors/windows would only place themselves in the wall properly if they were lifted above the base or below the crown. Some elements cut the crown properly and not the base; others cut the base properly and not the crown.
I have not found a workaround.
So...if other readers are running into problems, please post a screenshot of your issue and identify which library part is involved and where your opening reference lines are in the profile editor.
Thanks,
AC 28 USA and earlier • macOS Sequoia 15.2, MacBook Pro M2 Max 12CPU/30GPU cores, 32GB
One of the forum moderators
