I have been running into many instances of strange behavior of door and window trim (and sometimes frame) with the 12 library, even with proper opening reference lines. I've sent a file to GS with a number of examples, but I think it would be helpful if more people posted problems they are having with complex profiled walls here.
With proper reference lines and with wall embellishments at base and crown, I found that in some cases, doors/windows would only place themselves in the wall properly if they were lifted above the base or below the crown. Some elements cut the crown properly and not the base; others cut the base properly and not the crown.
I have not found a workaround.
So...if other readers are running into problems, please post a screenshot of your issue and identify which library part is involved and where your opening reference lines are in the profile editor.
Thanks,
One of the forum moderators
AC 28 USA and earlier • macOS Sonoma 14.7.1, MacBook Pro M2 Max 12CPU/30GPU cores, 32GB
