drawing another story using "traced as reference"
alex732
Hello!
I have to draw another story, and I am doing that by marking my ground floor as "show as trace refrence". the problem is, when I am making the slab for the ground floor, it does not follow the ground flour contour walls.( see pictures below). What should I do?
Thanks,
Archicad26 Educational | Windows 11 AMD RYZEN 6000 9, GEFORCE RTX
Your first screenshot shows that indeed snap to grid is turned on (there is a little dot near your cursor).  It must be disabled in order to model freely.
Separately - if your other story is relatively similar to the ground floor, it can be easier to copy the ground floor elements to that story and then edit them as needed vs modeling from scratch.  Even if the wall construction changes, if the reference lines are in the proper places, you can just select all walls on the new story and change their composite/type.  Etc.
AC 28 USA and earlier   •   macOS Sequoia 15.3.2, MacBook Pro M2 Max 12CPU/30GPU cores, 32GB
Eduardo Rolon
Check that you have not turned on "Grid Snap" under the "View" menu.
Eduardo Rolón AIA NCARB
AC28 US/INT -> AC08
another Moderator
Thank you so much, it really works!!
