dwg export: windows,doors layers?
Hi i want when i want to make conversion into autocad dwg that window will be on layer and door on other layer so i am using layer conversion table so for example structual engineering will be given to it layer called: wall on autocad side but what about doors and windows it seems there is no layers on archicad for those elements so i can not convert it into independent layer i hope there is solution for that and thank you
10 REPLIES 10
Very kind of you to use those words instead of "old" or "ancient" faces 😂
Thanks - hope you sort it out 🙂
AC 28 USA and earlier   •   macOS Sequoia 15.3.1, MacBook Pro M2 Max 12CPU/30GPU cores, 32GB
