embed dwg file
Options
- Mark as New
- Bookmark
- Subscribe
- Mute
- Subscribe to RSS Feed
- Permalink
2019-02-12 11:28 PM
2019-02-12
11:28 PM
I see incoming dwg file converted from Vectorworks is one flat file and is a lot smaller in size like 1 mb. Its embarrassing to send AC converted DWG not in one file. I am sure AC has the capabilities to do that. Anyone help?
Thanks
Lilian Seow
LEED AP | cSBA | CAPM | PMP
Interior-Architecture and BIM Management
AC28 USA | Windows 10 Enterprise i5 3.10GHz | Archicad-user since 1994!
1 REPLY 1
Options
- Mark as New
- Bookmark
- Subscribe
- Mute
- Permalink
2019-02-13 01:28 PM
2019-02-13
01:28 PM
I assume you mean you publish your layouts to DWG?
You can set up folders in publisher which contain several layouts (or just use the folders from your layout book, assuming you are using those) if you select one of these folders in Publisher, you can tick 'Merge to one DWG file' at the bottom. This will put all the layouts in that folder into the one file.
www.leloup.nl
ArchiCAD 9-26NED FULL
Windows 10 Pro
Adobe Design Premium CS5
www.leloup.nl
Windows 10 Pro
