Showing results forĀ
Search instead forĀ
Did you mean:Ā
Search instead forĀ
Did you mean:Ā
embed dwg file
Llian
I typically save PLN file to DWG file using the "00 DWG FOR DUMMIES". But the folder contain many separate files that are embedded with it. How do I "flatten" all the embedded files into one DWG file ?
I see incoming dwg file converted from Vectorworks is one flat file and is a lot smaller in size like 1 mb. Its embarrassing to send AC converted DWG not in one file. I am sure AC has the capabilities to do that. Anyone help?
Thanks
Lilian Seow LEED AP | cSBA | CAPM | PMP
AC 29 USA FULL | Windows 11 Enterprise i5 3.10GHz | Archicad-user since 1994!
1 REPLY 1
Erwin Edel
I assume you mean you publish your layouts to DWG?
You can set up folders in publisher which contain several layouts (or just use the folders from your layout book, assuming you are using those) if you select one of these folders in Publisher, you can tick 'Merge to one DWG file' at the bottom. This will put all the layouts in that folder into the one file.
www.leloup.nl
ArchiCAD 9-29NED FULL
Adobe Design Premium CS5
