2008-05-07 05:46 PM
2008-05-08 12:29 AM
KRAY345 wrote:I don't think you can. That's the purpose of Photoshop, pixel editing. (you can do some vector graphics also, but I don't think you can import a pdf like that.)
heya can anyone tell me how to transfer my plans into photoshop without it pixilating.
2008-05-08 02:55 PM
Thomas wrote:i need to print out my drawings and on the computers linked to the printers the have arch edu version 10. i am lucky enough to have the full version on my computer.KRAY345 wrote:I don't think you can. That's the purpose of Photoshop, oixel editing. (you can do some vector graphics also, but I don't think you can import a pdf like that.)
Perhaps you should tell us why you want it in Photoshop?
2008-05-08 04:43 PM
2008-05-08 06:37 PM
ejrolon wrote:problems with that is that its a huge plotter and it wont install on my laptop and i cant install the programme on the computer as i am not the admin.
Easy solutions;
1. connect the printer to your computer
or
2. Install the full version on one of the other computers and move your USB Key.
2008-05-08 06:42 PM
2008-05-08 06:44 PM
ejrolon wrote:as i said it pixilates and is not the same quality eg lines are thicker/ bolder
What's wrong with printing the pdf?
2008-05-08 06:45 PM
2008-05-08 11:48 PM
KRAY345 wrote:The only way that you can get pixelated results from printing a PDF is if it contains images. Any PDF generated from standard AC views will contain vector linework and scaleable text. So, it sounds like your layout sheets must contain images generated from the 3D window or from a rendering engine? Or placed there from an external source? If that's the case, you have to make sure that the placed image has sufficient dpi for your output device. It sounds like you placed some 72 dpi (screen res) content...
